Looking to get some advice and thoughts on this one.
I was taking a look in the loft recently and accidently came across an area on the roof space where there was obvious daylight shining through? No other areas in the roof space appear to show daylight only this particular area.
As far as I understand, there are no vents in that area.
I've only looked and observed at this from a distance via the loft hatch.
But from what I can gather, it appears to be daylight shining through the internal roof underlay. There seems to be 2-3 holes of light showing on the underlay. Having looked during the evening, there doesn't look to be any holes in the underlying (looking from a distance).
Not being knowledgeable on roof construction, but I assume behind the internal roofing underlay that we see in the loft is the actual roof tiles.
Hence, I assume what I'm seeing here is NOT normal and NOT good? Is it the likelihood that what I have is probably some damage to an actual tile (as per the holes). However, like I said there hasn't been any signs of water ingress from below the ceiling?
I wonder if water is getting through the holes, and simply running down the underlay?
Appreciate any thoughts and advice...
Loft - Video
loft-daylight1
loft daylight 2
loft daylight 3
external roof side
Loft - Video
loft-daylight1
loft daylight 2
loft daylight 3
external roof side
