It is a job I have put off for too long now and as its winter, it is now a bit of a problem!
I have double glazed, pvc patio doors - (not 3 way openers, just straight out door type openers!)
When I open the door, I have to practically lean my body weight quite sharply on the left hand door handle. The door swinging/ opening action does not feel impeded.
When I close the door, I have to really it pull it towards me and yank the handle quite hard upwards, to seal the door. The door closes fine - no rubbing.
Locking the door can be difficult if the yank was not upwards forceful enough.
There is daylight if the yank was not upwards forceful enough.
Daylight is seen at the top of the left hand door from the right edge for about 6 inches (from right to left hand side). Also, daylight is not obvious when it is dark
I did have a quick look this afternoon and noticed two slidey bits of plastic on the top and bottom of the frame - looks like they clipped onto runners. I can freely move these back and forth as if they were designed to do just that!?
I assume the clunky handle, key locking and daylight problems are related so what can I do to fix this? Also, are the slidey bits still meant to be there or are they intended for installation use only?
Any help or advice greatly appreciated.
Regards
Regards
