de frag
3 Aug 2007
Yorkshire
ive got a acer travelmate 459 1lci and it keeps saying low disk space ive tried to defrag it but i cant get enough space for it to do it ive taken evry thing of that it will let me and it wont let me remove any thing else i dont know what to do with it
Have you tried disk cleanup? how big is the drive? Do you have a Cd or DVD burner (recorder)
Defragging won't increase disk space at all, it mearly re-assembles files into contiguous space. You either need to delete more files or move some data onto a different media (external drive, memory stick, CD etc.)
Disk cleanup will remove any temporary files, but it's unlikely reclaim that much space.
Is the drive partitioned at all? If so, it's possible that the system partition is full. In this case, moving the swap file and any otehr data to another partition would give you some breathing space.
What i've done with my acer with two partitions is to use a partition manager to increase the c: drive capacity at the expense of the other partition. Not sure if you'll have enough capacity to run one though in order to resize them.
