I recently had a plumber unblock waste pipe flowline that branches into a shared communal vertical stack. Not sure if he used a camera but said the verticla stack was okay and ive not had any complaints from other flat owners connected to the communal stack
The plumber noted that the inside of the flowline pipe was quite badly scaled up with sediment and that without de-scaling, the pipe would likely become blocked in the future.
The flow line is about 3 metres of straight pipe with a rodding access point at one end.
Is it possible to de-scale this sediment easily with either mechanical tools or chemical treatment?
If so could you guys provide some suggestions
or is this a specialist job?
cheers
cheers
