Dead Nest E thermostat
11 Feb 2010
West Glamorgan
I recently installed a Nest E which worked fine once the battery on the base unit had been charged up. However the thermostat has stopped working in that it's just dead. Its powered via USB and the charger is working as I've checked it with another device, but the cable is hardwired so cant tell if there is a fault with that. Could there be an issue with the battery that is causing it not to work? Perhaps the battery can't hold a charge so despite it being permanently plugged in it won't work? It's not helped by many of the references online to Nest E refer to a wall mounted, battery powered version which is different to the freestanding, USB powered version I have. Any suggestions gratefully received.
Are you sure it’s the Nest E then? Does it not come on at all?
The thermostat is just dead. When I first plugged it in a few weeks ago when I first installed it, it didn't work, but after a couple of hours it came to life and has worked fine until today. The heating can be turned on through pressing the centre button on the heatlink that's installed next to the boiler. I'm sure its an Thermostat E - its the same as this one:
Apologies, yes it’s the Nest E, it’s the heatlink that’s usually wall mounted. If it’s under warranty Google will send another? Not sure what else to advise, sorry.
It can be a bit confusing - web searches for the Nest Thermostat E will inevitably include the American versions, which are very different units.
For clarity, the Nest Thermostat E heatlink is wall mounted and battery powered.
The thermostat itself, is USB powered and mounted on a non-removable (as far as I can tell?) base.
The thermostat however, does also have a non-userserviceable rechargable battery installed. As with the other Nest thermostats, this is used for bursts of power when it is sending radio signals to the heatlink etc.
The Nest wouldn't be able to send these signals and power it's other functions from the USB power source alone.
....although you've suggested the USB power supply is working, it might be worth leaving it plugged in to another charger overnight, and seeing if that brings it back to life.
Otherwise, contact Nest - you may have a faulty unit.
No problem and thanks for the replies. Unfortunately, it came free with a new boiler (from Mr central heating) which was purchased about 18 months ago, but I will try contacting google and see what they can do.
There have been some stories on here about Google being good at sending replacements, so it's definitely worth trying.
