Someone at work has asked me to look at there Sony VGN-N11M Laptop, its completely dead, no power lights nothing.
The power supply has a light on it and I have checked that it has 19v coming out of it, but the laptop does nothing,so I guess it will need a new system board, I could try taking out the RAM and Hard Drive to see if that is brining it down, but a bit unlikely,so I guess it will need a replacement system board.
I guess these are quite expensive?Any ideas cost and where I would get one, I looked on ebay and there is nothing there.
I have already given the guy a heads up that it is probably not going to worth repairing.
I have seen a similar problem on a IBM \ Leveno R40 \ R50, completely dead, but I had a good working spare one, so I swapped over the batteries, and it worked, the strange thing was that the battery from the faulty laptop worked in the good laptop, so I guess it might have been due to the fact that the battery from the faulty laptop was so low that it would not work in the faulty laptop, but was fine in a good one..bit strange though & I have seen exactly the same more than once with IBM \ Leveno.
Any thought appreciated.
Steve
Steve
