Hi!
As you can see from the title I'm having a spot of trouble with my boiler. Its a BAXI BERMUDA 57/3M. While my central heatiung works fine I'm getting no hot water. When the system is switched to hot water only the boiler fires but cuts out after about 10 secs. I know very little about this kinda thing and have only just moved into the house so have few details on the boiler itself.
ALSO!
the boiler is set in the chimney with the control section in the opening. I've since been told this is a deathtrap as it should have a fire front on and that gas cannot escape and I'm lucky to still be alive! Is this true? Can any type of fire front be added? Theres a constant(quiet) hissing noise from the boiler even when the CH isnt on. Can I add some kind of flue instead?
Any help is gratefully received!!!!!!!
ALSO!
