HI
I know I had another thread open in Januray but wanted to start this to get straight to the point so people don't need to read a lot of not that relevant preamble.....
Anyway, our shower has suffered from erratic pressure and after taking advice from the other thread I finally got round to looking at it. The filter from the hot inlet to the pump was clogged with plastic debris that looked like the trimmings from when the cold water tank was installed (at the same time but wasn't evidently flushed).
Anyway, I remove them and the shower is a bit better but still the pressure varies a lot. Given the filter was a simple grid, I think some of the plastic shaviongs could have made it through and further upstream certainly into the pump but maybe on to the mixer?
The problem I have is that the mixer is embedded in the wall so I'm thinking of cleaning it out by sending a jet of water at mains pressure the wrong way round - my theory being that any debris pressed against an incoming filter might just work its way lose if water is forced the wrong way.
Does that sound a reasonable approach?
