Decking between house and garden wall
1 Apr 2011
Manchester
I’m about to install a deck at the front of a terrace house and have a couple of questions. The deck will be 1.8m deep x 3.3m long which will be fixed to the house and the front garden wall (below the dpc). I was going to leave a gap of 10mm around the deck frame on the house and wall side and pack out with washers to allow for expansion, contraction and damp issues but wondered if this would be enough. As it will be packed out with washers and tight to both walls if it expands would it be likely to push the garden wall out?
The frame won't expand. Only the boards will expand across their width a few mm each, but that is catered for in the gaps you leave between then anyway. Don't worry about expansion.
