S
SplanK
Hi guys, can you have a quick look over the plan I have made for a ground level deck I am to construct.
All wood used in the frame will be 6x2inch... After much searching, it seems to be suggested that each bearer has a 400mm centre gap which I have done, but could not find much info about noggins so I have planned them with 800mm gaps. Not sure if this is enough, or far too much?
The top boards will run at a diagonal "straight" with the 785cm run.
Thanks for your time and any advise.
