Hi folks,
Want to crack on with the decking in the next few weeks but have some questions.
The frame is going to be supported on a single row of paving slabs at one end (by the house), then the plan is to sink some posts at least 2 feet in to the soil in concrete. But what's the maximum gap I should be doing them between each other? Deck size will be about 3.25m x 5.8m.
Also I plan on having 400mm gaps between joists with noggins every so often. However, due to the height of the back door I want to use 3x2 for the frame so the deck isn't sitting above the door theshold. Do you think this will be suitable? I'm willing to put more supporting posts in if need be.
Thanks very much
Thanks very much
