Decking framework?
20 Jun 2014
Merseyside
Hi all,
I was just after some advice on laying decking framework (2.7m x 2.85m)over a solid patio.
I wanted to use 4x4 for the outer frame,tanalised and then bitumen painted,and use 4x2 for the inner supports. Just seems wherever I read I should use legs,supports etc. Can anyone see any problems with my idea?
Advice really appreciated!!
No, just requires packing as required to bring level/flush...pinenot :)
Thanks pinenot,
I only need to raise it slightly,so I was thinking small red quarry tiles to lift it,and even just use 3x3 wood instead of 4x2.
Just read so many different things and complicated articles I am bamboozled.
You can actually take it down to 2" x 2" if height is not a problem, just remember to tack some 2" dpc under it...pinenot :)
what would you recommend to pack/level out a deck frame over existing patio flags. They are reasonabley level but will need a lift in certain places.
Old roof slate, you can put as many as is required, failing that get some plastic packers...pinenot :)
