Hi everybody, I have an small area of garden (about 4m x 2.5m) which I am planning to replace with decking. I want to put the new decking in at the same level as the existing grass. The way I was planning to do this was by cutting grooves in the grass/soil and pouring pea gravel in the bottom to bed the joists onto. The problem is that I know its not usually a good idea to put timber below ground as it will rot, although not sure how quickly if I used treated timber. Has anyone got any tips or bright ideas which might help ?
Also, there are existing walls on four sides so not sure what is the best way to place the framework, i.e. in one piece (heavy) and try to lower in or place each piece individually ?
Any help or opinions would be appreciated.
