- Joined
- 22 Oct 2015
- Messages
- 96
- Reaction score
- 6
- Country
Hey all
So the time has come to start planning the decking area that will be built outside of my Garden Room office.
We've got a reasonable amount of space to work with, so I'm looking at total dimensions of 5.5m x 4.9m.
I'm planning on building an outdoor kitchen on the deck, and possibly a corner seat, so the entire area won't be one open deck.
One catch is that the garden slopes down to the office, so I'm going to have to do a split level build.
The current plan is to have an approx 1m deep strip across the front of the office in order to allow for the french doors to open out, and then the main deck area will be approx 150mm higher.
The current plan is to use 2x6" C24 pressure treated timber, along with 4x4" posts for the legs.
I'm planning on digging and pouring some concrete footings, and settings in concrete-in post bases, e.g. https://www.toolstation.com/post-base/p82691. That way I shouldn't ever have any issues with posts rotting out.
The design looks like this currently:
I've designed the smaller deck as a single box. The large hole there is where a manhole cover is sited, so I'll be framing around that to allow access via a hatch.
The main deck is split into 2 boxes, with the span being 2.1m.
5 posts to each beam, which I think should give plenty of support.
The joists are going to be hung using metal joist hangers, nailed in place.
I'm also going to be using coach bolts to attach the beams to the posts.
And one more view to give an overview of how the decking fits into the Garden room.
So, anything I've missed? Or any other suggestions?
Thanks in advance.
Gavin
Thanks in advance.
Gavin
