Decking Q
22 Aug 2010
London
Hi Guys,
I know you get a fair few decking questions, but I just want some reassurance here.
I have an area that is approx 3x3m that I want to deck. It is framed on 2 sides by a raised wall. The decking needs to sit very low to the ground, ideally, so can't afford to high a frame.
I have placed 9 paving slabs leveled on concrete and now need to start buildding the frame. It's worth saying that my decking is going to be the harder Balau wood.
I gather that 400mm joist spacing is a good safe bet, but what wood should I use for the frame. I want it to be strong, but not too high. The frame is also not attached to verticals, but will sit straight onto the paving slabs....
if your sure its completley sitting on the slabs,then i see no reason why you cannot use tanilized 4x2.
