I am building some decking to replace the disaster that was left behind by the previous owner.
This area has to be slightly higher that the stuff that is already there due to the ground, solid concrete and rocks which are all uneven so I can make it ground level.
The area is approx 3m x 4m...I plan to sink in 12 posts in total, 4 rows of 3. I plan to fix a length of 6x2 along the 4 rows, so these will be circa 1.3m apart. If I build on top it will be far too high, so I was going to use coach screws to fix beams at 400mm apart or use joist hangers in between joists...will this be strong enough? Or am I better to notch the wood out, which is a load more work?
