Decking step runners
1 May 2003
Durham
Anyone know where I can get four/five step decking step runners ? The sheds only seem to sell three step jobbies.
Oh, and the decking I've inherited is c 33mm thick and the shed stuff is 28mm, I need two lengths. (Oooh matron !!)
Just an idea, maybe buy an extra 2 string then cut it where you want, drill holes for dowel, glue and join it together to make it longer.
Or screw it side by side which probably won't be noticed (?)
travis perkins do them, from the richard burbridge range. You could always make your own!
Thanks to you both for your help
I wouldn't make a good carpenter cry ....... He'd commit Hari-Kiri !!!!
Think maybe go with Masona as the steps are going to "taper" in on the way up (see, I said I was a crap carpenter !!)
Hi B&Q sell stingers that run to a hight of 5ft about 6 or 7 steps they r £16 each
___________________________________
Lynda, moderator, nice info, I bet the job is done now, since it was asked in 2005
