My new property has a natural wood (unstained) decking.
My property also appears to be in close proximity to a wasp nest - as a result, there are almost always a few wasps rasping away and the wood and the entire decking is essentially covered with scrape marks.
I'm dealing with the wasp nest separately, but is there anything I can do with the decking to make it less attractive to them?
Apologies, I'm a complete DIY novice. My assumption is I'd need to sand the decking down (and get a pressure washer on the mossy bits) and then I'd like to stain it with a nicer colour. Would woodstain repel wasps anyway - or is there something else I need to use? For instance, is there a woodstain that is specifically designed to repel bugs, or is there an additive I can mix in with woodstain to get the same effect?
