Howdy, am constructing a timber decking approx 6m x5m. The height will be 200mm from the top to the uneven base. Using 125mm x50mm joists with 900mm x 100mm x50mm noggins spaced at 400mm centres to support the deck. Question is what should be the minimum spacing of supports on the joists ?[/u]
