I don't know if powerwash will get it off unless it's very loose, the oil need to get into the wood so chemical stripping is one way with a wire brush or sand it off dry, might be best to ring the manufacter from the tin because some products don't bind with difference products. Try reposting this in Decorating/Painting/Tiling section.
