- Joined
- 30 Jul 2018
- Messages
- 1
- Reaction score
- 0
- Country
Just had an oil-fired boiler removed which was served by a stainless flue liner running up through a brick chimney which won't be used again. There's currently no chimney ventilation apart from the liner itself which is still open at the cowl. The liner at the bottom is actually mortared around its exit from the chimney. I can only guess that the air space between the inside brick of the chimney and the outside of the liner is unventilated but there's no chimney damp probably due to the liner heating up regularly. However, now the boiler's gone I'm guessing damp might become a problem unless I ventilate the chimney. The chimney runs up through the middle of the house, so only exposed to weather above the roof.
I guess the gold standard would be to remove the stack to beneath the roof line and leave it open, but I'm looking for a quicker and cheaper solution. I'd appreciate some advice please. My thinking is:
1. Puncture the liner where it enters the house on the ground floor. This will create an air flow between the liner and the inner chimney. I just hope it's not full of beads. I'd fit a plastic vent over the liner entry point (which is at the back of the disused boiler cupboard, so no issue).
2. Knock out a brick in the chimney within the loft space (not above the roof) and replace with an air brick.
3. Seal up the cowl above the roof.
This would be cheap as chips and within my DIY comfort zone, but would this cause problems I haven't yet thought of? Should I expect condensation inside of the liner too?
Any help or advice would be appreciated.
Thanks!
Thanks!
