Decoration material in shower room
4 Dec 2004
Hi
I am converting an airing cupboard into a shower. 2 walls are block & plaster & 1 wall is a stud partition with plasterboard& skimmed. a ceramic shower tray 800 x800 is to be install and a glass shower screen to be install.
To minimise cost & work:
Q1) Are there any other wall covering in the shower cubicle that I can use other than tiling?
Q2) If using tiling, do I need to treat the existing wall prior to tiling?
Q3) What to use?
Q4) Do I need to fix aquapanel or others prior to tiling?
Q5) How about the plasterboard & skimmed ceiling? Above is the loft.
Q6) What are the possible problem if none are carried out?
