I've had a gas fire fitted and serviced without additional room ventilation. for the last 4 years. Once in the past the gas fitter wasn't going to pass the ventilation but showing him the details on the fire he accepted it wasn't necessary and passed it. This year the gas fitter said it must have a hole in the wall. The original installation booklet is contradictory in that it states that the appliance should have at least 100cm2 vent. Immediately underneath it gives the dimensions as being maximum heat output of 6.5KW/hr and states it doesn't need purpose made ventilation unless needed.
My question, do decorative gas fires need a permanent air vent regardless of them being less than 7KW heat output?
