I have searched on here and gained a lot of advice - but just wanted to check what approach best for my situation.
The soil in the garden is mainly clay but with a bit of a finer topsoil. However there are lots of Oak trees in neighbouring gardens - some quite close to where the patio will be.
I want to pave a thin area (approx 2.5m average width by 10m long) at the side of the house which will flow into main patio which will be about 5m x 9m.
There is currently patio covering the bulk of this area which has been down as far as I can tell the entire life of the house (just under 10 years) There has been a little bit of movement in the slabs in that time, and in the summer some areas see a small amount of noticable movement (as the trees drink all the water??!!) THe main area of exisitng patio needs ripping right out as some idiot decided running towards the house was OK!!
The current slabs seem to be laid on a fairly coarse aggregate dry type mix - its quite strong but a little too crumbly I guess to have been wet mix - it's about 50mm thick and direct onto the soil underneath. It has obviously hardened and withstood quite a battering from the pickaxe in the smallish area I have pulled up so far!!
My main question is this - should I use a hardcore layer and compact that?
Can I use some of the broken up existing patio, bricks, even solidified dry mix base as hardcore for the new patio or should I be getting the finer stuff from the builders merchants and whacking it to a fairly hard compacted base? I was sort of toying with putting a layer of this down and then just dry mix on top.
Will I find it easier to establish a firm level(ish) base with some finer hardcore and then do a better job wet laying the slabs?
Just looking for the best longish term approach that won't see me pulling my hair out because of excessive movement within a year or two!! I've never done a patio (done decking but want a change from that) before.
I know what the text book answer is (and if that is correct then so be it) but it seems overkill to put down 75mm hardcore and then 75mm sand/cement on top of that - but maybe that is the only way to go.
Cheers.
Cheers.
