Hi
I have a bathroom and ensuit with a bath in each
I am in the process of doing the bathroom, the bath is gravity fed hot water 22mm, cold is 15mm mains.
I have run a new 22mm from header tank to the cold taps to achive a balanced mixer shower for both baths, I can't get to the tee to remove the dead legs on these so was wondering if possible I could just join up the two 15mm redundant supplys together creating a loop?
Would this solve the problem and create flow stopping possible contamination, or cause flow/ air restriction problems?
Thanks.
Thanks.
