Why is the home damp? Cure is to stop the water ingress to start with. This house sits at around 40 - 60% depending on time of year and weather.
Years ago parents house was single glazed with metal frames with catching trays at the bottom and small holes leading outside, so the windows became dehumadity units, the fires used air from the room, and vents in the wall allowed air back in, keeping the rooms dry.
Over the years fires have been sealed up, vents blocked, and double glazed windows in plastic frames fitted, later versions of double glazing included vents in the windows, but there is a balance ventilation and heating, the best option is a heat recovery unit, but these need installing.
In the main the bath room and kitchen allows mosture into the home, extractor fans in the bathroom and kitchen can help, but also reducing moisture getting into the home.
Gas cooking can put loads of mosture into the home, with gas cooker hoods vented outside, electric cooking produces much less mosture.
But also damp course failure, leaks in roofs, even faulty gutters can cause damp, in my last house the glass fibre in the roof space was by capillary action moving the water leaked through the roof tiles into the fibre glass filled cavity in the walls so walls always damp.
At the time we had no idea what was going on. No amount of running a dehumidifier will help.
However also homes which have been re-plastered can be damp, that is clearly temporary and a dehumidifier will help.
So why is your home damp? Clearly we exhale mosture so over crowding can cause it, including any animals (pets).
