[url=http://www.dieselnet.com/tginfo/abstracts.html]Click for DieselNet [/url] said:
Common Rail Fuel Injection
In the common rail system, fuel is distributed to the injectors from a high pressure accumulator, called the rail. The rail is fed by a high pressure fuel pump. The pressure in the rail, as well as the start and end of the injection in each cylinder are electronically controlled. Advantages of the common rail system include flexibility in controlling both the injection timing and injection rate. Stable pilot injections which can be delivered by the common rail have proven to lower the engine noise and the NOx emissions.
