In a new build, you can wait at least 6 months or longer before the fabric is dry enough to accept non-permeable paint or paper; I would never risk it on new plaster. Sorry but I would hardly regard the NVQ P&D manual as a definitive reference source for building/plastering but I’m not in the pro dec trade so I probably don’t know my asre from my elbow.Permeable paints only need to be used on surfaces that may not be completely dry
and thats not just my opinion its stated in the NVQ P&D manual which honestly is the best reference book for the trade,
An initial mist coat will be sucked dry by new plaster in no time, adding additional coats in quick succession keeps it moist & allows the plaster to “suck” the paint into the microscopic pores in the surface giving better adhesion. Thinning 40% may have a similar effect but I’ve never heard of anyone thinning mist coats that much. I’ve been criticised for advising 25-30%, many will tell you 10% is OK & some will say to use it neat. IMO, they are only interested in saving time & won’t be around in 5-10 years time when it either starts to crack & fall off or comes off with the wall paper someone else has stuck on there.it also makes no mention of multiple coats of primer. If you apply one coat of suitably thinned emulsion it does the job its meant to do which is satisfy the porousity of the plaster, subsequent coats are pointless.
