Depth of Concrete for SLAB
17 Jun 2009
Essex
Hi, I'm building a 4m X 4m single skin block outbuilding at back of garden.
I've compressed about 5m * 5M of hardcore 50 cm deep. 2 questions:
1) How much depth of sand do i need to compress on top of this
2) I'll place dp membrane over this and concrete above right?
3) how much/deep should the concrete be? 50 cm deep?
I live in Essex (clay).
Any help much appreciated - thanks.
this is my foundation - a simple slab - didn't think i needed much more for a single skin block wall?
Dig a footing, lay masonry up to dpc, then lay a membrane with the floor slab within.
You end up with a damp floor if you use the slab as a foundation and it is a pants way to build anyhow.
It's for an office - basically a desk, computer and a few books - i didn't want to go down the footing route because its clay plus a few trees within 5 meteres, thought a slab would suffice seeing as it's a one block thick building....
so guys anyone able to help with depth of concrete and sand required?
25mm sand blinding
1200 guage dpm
100mm c35 concrete.
I see the reason for building this way, technically not correct, but will do, i have a garage built on a slab and had no problems, at least if the ground moves the whole slab tends to, i would reinforce it and probably dig the edges a bit deeper to suport the weight of the wall.
