Designated Interior Drying Space
24 Nov 2004
has anyone ever heard of a "Designated Interior Drying Space"? it's for a newbuild residential house.
it's what I would have called a Utility room. it has the CH plant in it, and no windows. It does have a couple of doors, however, which I suppose is handy with regard to getting in & out of it.
anyway, A "DIDS" is evidently a requirement of the building warrant of the LABC in question. My Q is, is there any part of the IEE regulations that addresses them specifically? I can't find one but I have only perused the green OSG.
DIDS is not listed in the definitions in BS7671.
But BS7671 only refers to the electrical requirements.
Building Regulations (or LABC's interpretation of them) might have other requirements (eg the installation of a humidity extractor fan).
You should check with them.
Not in BS7671 there isn't, you may find that building regulations will require that the correct ventilation is offered to prevent moisture and mould growth
Too slow, mate!
I've got a feeling it's more of a Scottish building requirement.
With regard to the BRB you will probably just need to bear in mind humidity and heat. (Along with normal circuit considerations)
It's a Scottish requirement,
Section 3.11.6 Drying of Washing also indicates that a designated space for the drying of washing should be provided inside every dwelling, this to be in addition to the external space. It defines a minimal volume of 1m3 of clothes drying within a designated space (having no dimension less than 700mm), allowing 1.7 m of clothes line per apartment.
Apart from the inadequate length of clothes line specified, a major weakness is that the designated indoor space is not required to be an enclosed dedicated space. It could be as minimal as a floor space within a dwelling on which to set out a clothes horse or space for a ceiling mounted pulley.
Section 3.14.4, ‘Ventilation of areas designated for drying of washing’ indicates that this space should either have mechanical extraction capable of at least 15 l/s intermittent operation – the fan should be connected through a humidistat set to activate when the relative humidity is between 50 and 65% – or a passive stack ventilation system in compliance with a further clause.
http://homelaundrystudy.net/design.html#chapter04
and see
http://www.scotland.gov.uk/Resource/Doc/217736/0102070.pdf
So what are the regulations on the Orkney Islands?
Is it mandatory to wear high heels and skirt?
Oh yes.
