I've ordered a fancy designer radiator (1800mm high x 500mm wide) and just want opinions on the best way to get the pipework to it.
Is it best to run the pipework up from the floor to the valves like with a standard rad or would it be better to chase the pipes into the wall so they come out behind the radiator?
If I chase the pipes, is it OK to use speedfit plastic pipe with speedfit elbows where the pipe comes out of the wall or is that a definite no no? I was thinking of burying them quite deep then just plasterboarding over and skimming level to the rest of the plaster?
Cheers
Rob
Cheers
Rob
