Hi
I recently moved into a new house with a Honeywell Accenta/Optima alarm. The previous owners didn't use the alarm, so didn't know the code. At some point, I was going to get round to resetting... Today, I decided to turn off the annoying chime that goes on entry.... as this doesn't need the code...
However, a few seconds later the interior alarms starting wailing... and then a little later, the external. After much panic, I had disconnected the panel on the wall (I think this is called the Accenta LCD Keypad) and powered off the electricity to the house. Of course, it kept going.. and stopped after 15 mins.
I reluctantly turned back on the power to the house and fortunately, the alarm did not reset. The blue strobe on the bell box is flashing away however, (this doesn't upset the neighbours quite so much though!)
I have a couple of questions:
1) Is it possible to have just the LCD panel and nothing else? I searched on how to reset the alarm to factory settings and this implies that connections on a larger panel needs to be shorted.. I don't seem to have anything but the LCD keypad. Is this possible? I have searched high and low and can not find a larger panel anywhere. I've looked in every cupboard, room, loft etc... and it's not to be found!
2) Is there a risk that the alarm will go off again? 3pm on a Sunday is bad enough... 3am might not endear me to my new neighbours too much...
Any help really appreciated.
cheers,
Simon
cheers,
Simon
