I want to use the existing doorbell button wiring to power a camera doorbell, which needs 12v AC or more. The existing doorbell transformer is 12v, 1A. So far so good.
There are four cores in the thin wire leading to the front door button: red, yellow, blue and black.
The red and yellow are wired to one screw terminal. The blue and black are wired to the other.
I've tried to check the voltage available at the button using a multimeter across the terminal screws. No voltage detected in either AC or DC modes, whether I push the doorbell button or not. A non-contact voltage detector pen thing does beep and flash near the wires though.
Any suggestions why my multimeter can't measure the voltage?
(I can't check the voltage at the chime because it was boxed in behind plasterboard last year as I thought we didn't need it.)
