- Joined
- 6 Sep 2004
- Messages
- 1,069
- Reaction score
- 71
- Country
I have recently been experiencing a loss performance to my Dell laptop which runs under XP (Home Edition). It has a 1.5Ghz centrino chip and memory of 512mb.
Viewing the CPU Usage in the Windows Task Manager usually fluctuates between 25% - 50% when hooked up to the web and the response time is generally pretty good. The problem seems to begin when running a video clip. For instance a couple of days ago I looked at a couple of the clips of Planet Earth on the BBC website. It takes a while to load but eventually gets going. WTM then shows CPU usage right up to 100%. Perhaps this is normal but the trouble is that this rate of usage stays at 100% even after the clip finishes and the window is closed. At this stage the screen can go blank and the touchpad refuses to acknowledge any contact. Being locked out like this can last for a few minutes. Any ideas as to what can be the cause of this problem? Any help appreciated.
