Happy New Year,
I was lucky enough to get a Dewalt DWS777 sliding mitre saw for Christmas. It’s my first sliding mitre saw so I’d be grateful for some advice:
When performing straight cuts on wide lengths of material the instructions say to lower the blade fully and then pull it towards me (i.e. away from the fence). Is this correct? I’ve seen videos on YouTube showing this the other way round (i.e. pushing the blade away from me - which seems safer!)
I also need a fine tooth blade for cutting MFC. Screwfix do a 60 tooth blade (8078V = DT1929) which according to the Q&A will fit the 777:
https://www.screwfix.com/p/dewalt-tct-saw-blade-216-x-30mm-60t/8078v?_requestid=82372
However this has 5 degree positive rake angle whereas I understand mitre saws should use blades with a negative rake angle. Is this correct?
Would I be better getting the DT4350 blade which has a 5 degree negative rake angle?
https://www.toolstop.co.uk/dewalt-d...MI4IDP0Nb67QIVjevtCh0NiQH1EAQYAiABEgKbcvD_BwE
The DT4350 is a lot more expensive but I won’t be using it that much and I believe DW blades can be resharpened a few times so I’m happy to get the negative rake blade if it is safer or will give better results?
Thank you
Davey
Thank you
Davey
