I'm looking to buy an SDS drill, initially to facilitate chasing some pipe into a wall but also for future diy jobs. I found the following dewalt for sale which seems like very good value
i would like to see you try chasing a wall with that one, it doesnt mention rotary stop
it does say Ideal for drilling anchor and fixing holes into concrete and masonry from 4 to 22mm in diameter
Impact-stop for drilling in wood, steel, ceramic and screwdriving applications
Full wave electronic variable speed for total control in any application
Safety clutch eliminates sudden high-torque reaction should the bit jam
Ergonomic rubber coated pistol grip handle design for improved comfort in use
High drilling rate due to revolutionary motor design
but no mention of rotary stop (impact stop is not the same) now you know why its cheap
i have an erbauer 110V 650W. was about £80. only gets used for my own jobs/sometimes at work if there is a drill shortage (as in 'i cant be arsed doin work by hand')
