I have an intermittent fault where i can get HW, but the CH is now almost non exsistant.
The CH now only works if i run the HW tap for a few minutes, it then fires up the CH after a couple of minutes. However, it can't maintain the heating and will only work again if you run the tap again.
Someone i spoke to suggested it may be the Temperature sensor on the CH side needs replacing.
Is this likely to be the problem or something else? Any help greatfully welcomed.
