DHW controller
24 Nov 2004
pls could someone recommend a single (preferably double-width faceplate size) controller for an electric DHW system:
inputs:
2 separate incoming supplies (one remote-switched cheap rate, the other 24hr normal rate)
outputs:
2 electric immersion heaters (one 3kW at the bottom, one 2kW at the top)
Erm, How do you want the "controller" to control?
Usually you have the off peak on all the time (heating up the water at night, with cheaper power) and a boost control for the top immersion that is used if the main tank runs out of hot water.
Please explain what you expect to happen.
yes when I actually engaged brain I realised that's how it should be set up, so my Horstmann e-7 is just a controller for the boost at any time of day and the cheap rate is hardwired, and looks after itself.
thanks
