Getting towards dhw in the House of Pain.
Hot water source will be mains through a plate heat exchanger on the thermal store, supply pipe is 25mm into the house then 22mm to the hex. Pressure and flow both good.
Bathroom 1 (6 metres) will have bath and overbath shower and basin
Ensuite (16 metres) will have shower and basin
It is possible that both will be used simultaneously
Will i best mitigate pressure drops by running seperate 15mm feeds to each room from the 22mm output of the hex or should i do something else?
TIA
TIA
