I have a Vokera linea 24 that is showing code 6 which on reading manual informs me this is "Hot water open circuit", any advice on what this means and any way forward would be greatly appreciated.
Its very easy to replace. Isolate the electrics and mains cold water into the boiler, open a hot tap, get yourself a 13mm spanner, remove old sensor, fit new sensor (don't forget the washer).
