DHW preheat firing up every 11 mins (ISAR HE24)
21 May 2008
Shropshire
And its doing my head in, IsarHE24
Thisisi not normal is it, was firing up every hour, now firing every 11 minutes
Have turned it off at boiler, and back on, but still firing every 11 mins
You must have a dripping hot tap or a dripping leak somewhere on the hot tap pipe work.
Turn the cold mains supply to the boiler off under the boiler. 15mm pipe between gas and CH return.
If it stops firing it has proved the point.
Have no dripping taps, just checked them all, where do i tirn it off right at the top of the pipe (a little brass thing)?
Yes. 90D turn. Use adjustables rather than a screwdriver if poss. I have had these shear off with a screwdriver.
it must be something to do with the hot fill on wasking machine, it has a small leak, so have turned the latch to off ad aslo turned the supply to it off but it must be leaking through somewhere
have sorted washing machine out and it has stopped firing up now, so obviously the turn off valves where letting it through somehow, thanks for all your help
