Hi all
Have a new Vaillant Ecotec plus 832 and would appreciate any advice. I currently have my domestic hot water temperature set at 50C and when drawing off water through the tap the boiler display shows temperatures rising to about 15C above the set temperature. I have checked the temperature of the hot water leaving the tap with a suitable thermometer and it is coming out at around the set temperature of 50C, but can't understand why the boiler is displaying well in excess of this (e.g. 65 C). I feel sure that if the DHW temperature on the boiler was set at its maximum of 65C, the boiler would be showing temperatures of at least 80C?
The above does not happen as much when heating the radiators, as this is set at 60C and at most only shows temperatures on the display of 64C. The installer does not seem to think it's an issue, but would really appreciate other opinions as I don't want to risk damaging the boiler.
Before new boiler installation, previously treated water in my radiators when drained did look clean, though was still re-filled and flushed prior to new boiler installation and again after with Fernox F3. The installation also includes a MagnaClean and Magnetic Limescale Inhibitor fitted to the water supply pipe. Thanks in advance for any possible Help.
