DIAGNAL DECKING HELP!
6 Mar 2014
Down
I am planning to build my first 20ft x 20ft deck at the bottom of my garden. Area is pretty flat with a very, very slight slope. I am planning to use a diagnal pattern for the deck boards and obviously need more than one board spanning corner to corner. I know that the joists should be 12 inches apart but do I need to worry about the end of each board attaching to the joists. Do I cut it at a 45 degree angle or just let each board end between joists? Would you recommend a very long 4.8m board or shrter 3.6 meter boards and how should these be staggered to look the best? Thanks for any help. T
Each end of each board must be supported. Your joist work will be at 90deg to your boards, so ensure a double joist occurs at the intended meeting point. Or, as said, be more creative wih the pattern.
