I need to fit a 300mm long, 107 diameter max vent for a fan through a layer of tile and bricks, totaling 300mm thickness. I purchased a diamond core bit (diameter 107mm) with a 8mm guide bit and will hire a clutched drill for the job. I also purchased a 10mm X 300mm masonry bit to drill a pilot hole.
My questions:
1. the diamond core bit is dia 107 mm but so is the max outside dia of the
vent pipe. Will this be an issue? Should I drill wider or just finish off with a cold chisel if the pipe doesn't fit straight away?
2. the pilot bit is of 10mm diameter and the guide bit is a bit less at 8mm. Is this going to be a problem? Should I buy a smaller pilot bit to make sure my sure my end result is straight?
3. how do I get through the surface layer of tile? Do I need to do anything special like drill around the contour of where the diamond core will drill, say with a 5 mm bit for example? Or do I just go in with the the diamond core bit straight away after I've drilled the pilot hole? The entire hole will be contained within the surface of one tile, i.e. no drilling accross grout.
Any other tips?
Thank-you.
My questions:
Any other tips?
Thank-you.
