I've just broken up an old concrete path, about four inches thick, first using a grinder to cut it into sections before carefully applying the sledgehammer. I used ordinary stone cutting discs to cut the concrete and they wore down in no time at all.
I have another four square metres of concrete to take up and would rather not use the bog standard discs again, so I'm thinking of investing in diamond blades.
Do forum users consider the diamond versions to be worth the money in terms of cutting efficiency and extra cutting capacity?
Ta.
Ta.
