I have a slate roof at 30 degrees pitch, supported by metal trusses and 9x3.75 inch purlins. The distances between trusses is 4m. The distance between purlins is about 1.5m. The slates sit on battens, which sit on boards(like floorboards) that sit on the purlins. The purlins are rotated so the 3.75 inch face sits on the truss. Here's a pic
http://1drv.ms/1xA2V6l
A steel frame is being erected inside and 4 of the steels follow the profile of the roof. They were supposed to touch the purlins in the same way the trusses do but it looks like a couple of the steels are slightly in the wrong place so the erectors have just chopped a 40mm chunk out of the purlin that was in the way.. Annoyingly, they could probably have got away with just taking 15mm or so out
I've a concern now that the remaining purlin thickness might not be sufficiently strong for the load it bears. Can any one tell me if it's ok? I'm planning to pack out the gap so the syeel frame supports the notched purlin but if it would be better to tell them to not repeat the behaviour then i will..
