I will not repeat the above but I will point out
Part P click here for Government Page
Note that's a link to Approved Document P, not to Part P of
the Building Regulations.
Part L tells us what bulbs we can use
No it doesn't - Part L says:
L1 Reasonable provision shall be made for the
conservation of fuel and power in buildings
by─
(a) limiting heat gains and losses─
(i) through thermal elements and
other parts of the building fabric;
and
(ii) from pipes, ducts and vessels used
for space heating, space cooling
and hot water services;
(b) providing and commissioning energy
efficient fixed building services with
effective controls; and
(c) providing to the owner sufficient
information about the building, the
fixed building services and their
maintenance requirements so that the
building can be operated in such a
manner as to use no more fuel and
power than is reasonable in the
circumstances.
and Part M the heights of sockets on the wall.
No it doesn't - Part M says (regarding dwellings):
M1 Reasonable provision shall be made for
people to—
(a) gain access to; and
(b) use the building and its facilities
M4 (1) Reasonable provision shall be made in
the entrance storey for sanitary conveniences,
or where the entrance storey contains no
habitable rooms, reasonable provision for
sanitary conveniences shall be made in either
the entrance storey or principal storey.
(2) In this paragraph “entrance storey” means
the storey which contains the principal entrance
and “principal storey” means the storey nearest
to the entrance storey which contains a
habitable room, or if there are two such storeys
equally near, either such storey.
but that the requirements of Part M do not apply to—
(a) an extension of or material alteration
of a dwelling; or
(b) any part of a building which is used
solely to enable the building or any
service or fitting in the building to be
inspected, repaired or maintained.
Part F tells us size of fan in kitchens and bathrooms etc.
No it doesn't - Part F says:
F1 There shall be adequate means of ventilation
provided for people in the building.
