i will be trying to fit a new hot water cylinder and i was wonderng how would u tell the differance between the 2 diffrent types of cylinder without stripping it out
usuallys theres a lable telling you,but if you have any three or two port valves on the heating system, then the answer is indirect.if its run off a solid fuel appliance it could be direct, then you would have to look in the loft to see if its one cws.
