Hi I had an external Thermalite block (the 2.8N/mm2) wall rendered a few years ago, PVA was used in the mix - its all still up and looking good.
I have just rendered an external Celcon block (3.6N/mm2) wall myself, I was advised to use Lime in the mix.
What is the difference, does the PVA simply ****** the suction ? where as the lime helps with the flexibility, to limit cracking ?
On a side issue, I painted a slurry directly onto the Celcon wall, with Bond-It SBR in the slurry - I understand this is used to ****** suction and help with priming.
I am applying the top coat a week after the scratch base coat - I assume simply wetting the wall and applying direct - it will key.
I am having trouble scratching - I need to leave the base coat long enough to sufficiently harden before I can feather edge it (without dragging off the render) but by this stage it can prove harder to scratch it - whats the best technique for the base coat - I see some dont feather edge - and simply scratch the freshly applied render.
