Hello all,
I'm in need of a couple of extra double sockets in my living room. As a long time reader here I thought I'd take the plunge with my first post to get any thoughts on my two current theories for how to go about it... Any thoughts appreciated!
Option 1.) There is a Switched FCU on the wall I need sockets on, which is a spur from the downstairs ring, and supplys a set of wall lights. I'd seperate the FCU from the light switch, then run a spur from the FCU to the new sockets. So it'd look like this:
(ring socket)->-(fcu)->-(new socket A)->-(new socket B)
I'm not sure if this is allowed, I've read conflicting info on whether or not multiple sockets on a spur are allowed if the spur is fused. The fcu would also feed a switch for the wall lights. Thinking about it, the wall light switch would need to be seperately fused with its own 3A FCU, yes?
Downside to this plan is that the floor is concrete, and there is a radiator on the wall between the FCU and where I want the new sockets, which would make running the spur cable behind the wall awkward.
Option 2.) Tap into the ring upstairs, extending it to include the new sockets downstairs. Ideally I'd like to do this using junction boxes to tap into the upstairs ring, rather than running new cable from an upstairs socket (less plasterboard to destroy)
(upstairs socket A)>>>(junction box)>>>(downstairs socket A)>>>(downstairs socket B)>>>(junction box)>>>(upstairs socket B)
Downside to this is I'd need to lift the chipboard floor upstairs to tap into the ring and feed the new cables down to the room below. Urgh.
Any thoughts at all on these options, good or bad, would be great.
Chris
Chris
